thttpd.RejctConnAccessDeny
Description
HTTP connection request from the specified source IP-Address has been rejected by the configured access-list. This connection will not be permitted.
Remedy
Check the access-list associated with the application. Verify the rule order is correct. Use 'debug thttpd show access-profile' to view the order of access-list execution. Use 'show access-list dynamic rule <rule-name>', where rule-name is the name of the rule in the log message, to see the access-list that blocked the source IP.
Severity
Warning
Message Text
HTTP connection request from the source %address% has been denied by the access-list %rule%. Rejecting connection.
Message Parameters
Name Type
address String
rule String
Applicable Platforms
